Echostorm
Apr 02, 2024Guide
Re: I am having the worst disconnection problems imaginable
My 2.4 Ghz Devices are unusable they constantly disconnect! I even bought MORE satellites so that I now have 4 satellites so my IoT coverage is impeccable HOWEVER this has made things worse as satel...
Echostorm
Apr 05, 2024Guide
Sorry to clarify all my 2.4 GHz are already on a dedicated IoT network channel 11 (there’s an issue with Sonos speakers on other channels), what I noticed from my garage door opener is that it treats the IoT network the same even though there are 5 of the same IoT network in range, when it decides to roam between the satellites (I can see it connecting in the Orbi app) to the one furthest away with the weakest signal is will continuously drop. It seems like there should be some optimization from the router to prioritize its strongest connection and or to disallow it to connect to a weaker satellite. better
Apr 05, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What devices do you have connected in total?
What channel configurations are currently set on the router? Try channel 6 and 40 or 44.
Are you using the separate IoT network for the IoT devices?
Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
If you turn OFF the farther RBS that this one device connects to, does this device connect to a near RBS or the RBR?
