sgarr
Dec 05, 2023Star
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970. When I first got it every time the pixel would connect to the router, the router would immediately reboot. They gave me beta f...
sgarr
Jan 04, 2024Star
I am having the same issue with my pixel 8 pro and the orbi 970. I purchased 3 100ft ethernet cables to try and place the satellites as wired access points and I purchased the netgear cm2000 modem last night and will see how it does. Will have an update on Saturday to see if that does anything. At the beginning the router would reboot when my phone wifi signal was handed off to the router, now it just kicks the phone off the network when walking around the house even with full signal. It works fine on the Iot network but that is 2.4ghz I think and I require more bandwidth than that. The Orbi 960 series worked great and right now I regret the upgrade to the 970 series. My current firmware version is 9.10.4.1.
cmftblynu
Aug 17, 2024Star
That isn't your issue, mine are all hardwired (to a 10G wired network to boot) and can't get pixel 8 to connect reliably. It has nothing to do with my sattelites, it is only google stuff...
