Starcade
Apr 12, 2025Follower
Re: Interruption every hour
I’m having a similar issue with my 870’s. It’s best summarized by this post which has been locked for some reason: https://community.netgear.com/t5/Orbi-WiFi-7-BE-Mesh-Systems/Re-Interruption-every...
Apr 12, 2025Guru - Experienced User
Does the front LED on any of the units turn pink when this happens?
Happends with the RBR oor RBS?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Armor, IPv6, Smart Parental Controls or Circle, Logging, Traffic Meter.
Try a factory reset and setup from scratch...
My 870 series has been online for past couple of weeks with out any issues seen to date...
