Tcrus
Feb 22, 2025Luminary
Orbi 970 Ethernet Backhaul question and unmanaged switch
1. I can hardline backhaul one of the sattelites to my router but the second sattelite can not be. WIll this affect anything and will the wirted backhaul actually help? 2. How is running an unma...
- Feb 22, 2025
Thanks for the reply Crimpon, aftere hooking up the 970R and 970S my wireless speeds are BLAZING. Previously on my Orbi AX6000 i was getting 400 maybe down and now I am gettign 1400 down. I might try the wired backhaul and see if it makes a difference but like you said I doubt I would notice. I am pleasantly surprised with the 970! I do have one sattelite left thinking of making an enclosure and chuck it in the garage for max coverage...............
