Roc1
Jan 30, 2025Luminary
Re: Orbi 970 Wired Backhaul not Woking
@eFurry , @donnawalt , CrimpOn , my rbe971/970 system went down yesterday morning. NG won’t tell me, but a similar meltdown a week ago dropped all my devices but I was able to reconnect the hard wired...
Jan 31, 2025Guru - Experienced User
One test that you can do, Turn OFF all RBS. Does normal wireless work over night and into next morning?
Does both RBS exhibit this front LED behavior or only one?
If you bring the RBS to same room as the RBR and let them wirelessly connect, does front LED turn BLUE then eventually turn OFF?
After that, ethernet connect both RBS to the back of the RBR with ethernet cable and then does front LED maybe blink WHITE then turn BLUE then should turn OFF and remain off? Give about 10 minutes for this.
I would open up a support ticket now regarding this since your warranty period is getting close.
