userguy
Feb 14, 2025Tutor
Re: Orbi 970 Wired Backhaul not Woking
I'm not even doing 10g backhaul, it doesn't work using 1 gig, from what I've seen. Just bought an Orbi 970 with two satellites. I've upgraded to firmware 9.12.5.3 on RBR and RBS. I'm running in A...
Feb 14, 2025Guru - Experienced User
What brand and model# is this NG Switch?
For wired BH to work, need the following configuration:
Fiber Internet cable to router outside interface
Router inside interface cable to Orbi RBR WAN Port
netgear switch port 1 to Orbi RBR LAN port.
Netgear switch port 3 to Orbi RBS #1
Netgear switch port 4 to Orbi RBS #2
- userguyFeb 14, 2025Tutor
Netgear GS316 — 16 Port Gigabit Ethernet Unmanaged Switch
- donawaltFeb 14, 2025Hero - Experienced User
I was going to say something similar. Wired backhaul works fine in the proper setup. I do use my Netgear 971 as a router not an AP, but with Eth BH I am getting multi gig on laptops.
The big issue I see is as FURRYe38 said you have the router and satellites connected to an unmanaged switch and then to outside interface. The Netgear router needs to be on the other side of the switch, with the satellites then plugged into the switch. Use FURRYe38 's recommended config and see what you get.
Check out these two links for Netgear's direction on setting up wired backhaul:
page 23 of the 970 user manual, shows 971s connecting through a switch:
https://www.downloads.netgear.com/files/GDC/RBE973S/RBE971_RBE970_UM.pdf?utm_source=chatgpt.com
Knowledge Base article describes the same thing:
Page 23-23 shows the connection if in Routing mode, not access point mode. Which ports should I be using on the RBR for this to work? Same for the RBS in Access Point mode? Does it make a difference?
