bigkahuna01
Apr 27, 2025Aspirant
Orbi doesn't see an internet connection when connected to 2.5gbps port on modem
I have a new internet provider (EzFiber) and they have installed a Nokia modem and my plan supports 2.5 Gbps and their technician validated that I am getting 2.5 Gbps on the modem. I have connected m...
- Apr 28, 2025
The modem was changed yesterday because of some ISP issue. There were setting on the old modem containing my Orbi's MAC and IP Address that were causing a conflict with my replaced modem (New Profile) that were resulting Orbi not getting an IP Address. 2nd level support cleared the old modem's profile from the system and everything is working as expected. Thanks to everyone for their suggestions.
Apr 28, 2025Guru - Experienced User
Might also give a non managed switch a try as well. NETGEARs MS105 is a 2.5Gb supporting non managed switch.
Hoping that the ISP can clear this up though.
Keep us posted.
bigkahuna01
Apr 28, 2025Aspirant
Tried switch but no luck. ISP sees the MAC Address of my Orbi and also sees that they are not able to assign it an IP Address. They will get back to me by EOD today. Hopefully something will change
- FURRYe38Apr 28, 2025Guru - Experienced User
K, seems like this is some odd ISP handling issue. Hoping they can help figure it out.
- bigkahuna01Apr 28, 2025Aspirant
- FURRYe38Apr 29, 2025Guru - Experienced User
Figured it was something on the ISP side. Glad they found it and fixed it.
Enjoy. 📡 - bigkahuna01Apr 29, 2025Aspirant
Thanks for this 🙂
