irishleeriley
Apr 20, 2026Aspirant
Orbi RBE871 not recognizing all devices on Wifi
Our network worked fine until a few weeks ago. (We have a router and one RBE870 satellite.) Now it's not showing all devices as being connected, even when they are connected. I can look in the app an...
Apr 20, 2026Guru - Experienced User
What version of the Orbi app are you using?
Same thing seen on the RBRs web page?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Using ISP Detected DNS or custom DNS?
Is IPv6 Enabled or disabled?
Which ISP are you connected with?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
