WiFlying
May 03, 2025Tutor
RBE771 slow download fast upload
I've just upgraded from a 2019 Orbi to the WiFi 7 Orbi 773. I'm on Ziply fiber, with 1GB each direction. The net connection comes into a pfSense router, which is connected to a switch. The Orbi is co...
Mikey94025
May 03, 2025Hero
WiFlying wrote:
If I run a speed test directly in the Orbi app on the phone, it shows perfect connectivity, with near-identical upload and download speeds in the (Mbps) 800ish to 950ish range. Yet if I run the actual Oookla speed test on that same phone, it shows 250ish Mbps down and 650ish Mbps up. This makes no sense to me, as the Orbi app's speed test is powered by Ookla.
My understanding is that Orbi's speed test function occurs at the base router, not in the client where you are running the Orbi app or a browser connected to orbilogin.com. The Orbi app speedtest page says "It detects the download and upload speed from your router to the Internet". So the Orbi speed test does not measure or include your home network connectivity between the base router and your device (phone or laptop).
When you run the Ookla speed test on the phone, via their phone app or via their website in the phone's browser, then it does measure the speed all the way to your device (phone or laptop). This method does includes your home network connectivity, 2.4Ghz/5Ghz/6Ghz wireless, etc. between your router and your device.
Does this difference in testing help to explain your measurements discrepancy? Is there something in your home wireless path (router to phone) that would limit or cap download speeds but not upload speeds?
- WiFlyingMay 04, 2025Tutor
Thanks for explaining what the speed test on the Orbi itself is measuring; that explains the good results there.
No, and the problem is that it's not just the phone, it's every single Apple device: Phone, desktop Mac, laptop Mac, and iPad all have the exact same results: Download speeds are 3x to 5x slower than upload speeds. But my Windows box does not have that problem; it's showing the same upload and download speeds.
This would say there's either a problem with iOS and macOS, or there's a problem with the Orbi when talking to iOS and macOS. I honestly don't know which it is, but I suspect the Orbi more, only because a buddy of mine is also with my ISP, also at gigabit speeds, also on Macs and iPads and iPhones, but *not* on an Orbi ... and he isn't seeing these issues.
In looking at the speed test results I ran on my old Orbi, before I installed the new Orbi, I was seeing the same thing—but it didn't stick out as much because overall both the upload and download numbers were much lower overall. Hopefully Netgear support will be able to help me figure out what's going on.
After more investigation, I believe the real problem here is with Ookla's speed test, not anything particular to Apple's hardware or my network. I tried a bunch of web-based speed tests, and I couldn't ever get results like I was seeing with the app on my network.
As an example, here's what I got from Cloudflare's speed test:
Immediately after that ran, I ran Ookla's app (this was using my Mac laptop), and got download speed (using the server they chose) of 120Mbps and upload of 670Mbps. Then I spent some time choosing servers manually in Oakla's test, and found one where I consistently saw equal upload and download speeds in the 850 to 925 Mbps range. I found a couple more like that, as well as a bunch where the download would be anywhere from 50 Mbps to 250 Mbps.
In short, it seems Ookla's results, at least on Apple hardware, are *very* dependent on the server chosen for testing, and the auto-selected server may not be the best.
This still doesn't explain why I don't see the same issue when running the test on my Windows machine on a server that reported slow Mac results, but at this point, my thinking is that it's either an issue with those servers and file transfers to Apple hardware, or with Ookla's protocols on those servers for Apple hardware.
Either way, to back up the speed test results, I found some sites that offer test file downloads, and on those sites, I was seeing download speeds well in excess of what Ookla was reporting using its default servers. So in the "real world," my results are much better than the Ookla speed test results, and I don't think I have an issue here at all.Sorry to have wasted everyone's time.
