pboone424
Jul 13, 2024Aspirant
Re: RBE971 drops offline & reboots continually, ready for return
Well seven months later the issue really hasn’t been fixed but just reduced in frequency. I’m seeing both WiFi and wired networks go down at the same time for 3-5 minutes at random every 1-5 days. Aft...
Jul 13, 2024Guru - Experienced User
Does the front LED on the RBR turn PINK when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Is IPv6 enabled or disabled on the RBR?
Others have posted that putting a USB fan on top of the RBR has stopped the RBRs mysterious reboots or disconnections...Something you might try.
