AshDeezy
Apr 08, 2024Aspirant
Re: RBE971 Firmware Version 9.12.2.1 Issues
Hi, I just experienced the same issue on firmware V9.11.1.1_1.2.2 in the USA. My iPhone alerted me that this network was there, showed momentarily connected to the NTGRBH_XXXXXXXXXXXX network but th...
Apr 25, 2024Guru - Experienced User
Any progress on this?
AshDeezy wrote:
Hi, I just experienced the same issue on firmware V9.11.1.1_1.2.2 in the USA. My iPhone alerted me that this network was there, showed momentarily connected to the NTGRBH_XXXXXXXXXXXX network but then switched back to my primary one.
I just had to factory reset the RBR because I was getting super slow speeds when connected to the RBS (I think). I did not see this network the first time I set the system up. I changed my SSID and password as well for the first time in years just to get everything fresh again (super fun).
FURRYe38 what do you mean by this?
FURRYe38 wrote:
I presume up updated the RBS first, along with the RBR lastly?
When I performed a master reset, I did it by going to the router portal 192.168.1.1 and went to ADVANCED > Administration > Backup Settings > Erase
Is that not what I'm supposed to do? Should I have instead used the hardware reset buttons?
- AshDeezyApr 25, 2024AspirantAfter performing master reset via the portal I was still having slow connectivity issues. I found via another post on Reddit that having a Sonos speaker connected to the Ethernet backhaul port on RBS will cause issues. Removing the speaker from that port fixed my issues and all is working well now.
- FURRYe38Apr 25, 2024Guru - Experienced User
Interesting. Glad you got it working. Thank you for letting us know. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
