AshDeezy
Apr 08, 2024Aspirant
Re: RBE971 Firmware Version 9.12.2.1 Issues
Hi, I just experienced the same issue on firmware V9.11.1.1_1.2.2 in the USA. My iPhone alerted me that this network was there, showed momentarily connected to the NTGRBH_XXXXXXXXXXXX network but th...
AshDeezy
Apr 25, 2024Aspirant
After performing master reset via the portal I was still having slow connectivity issues. I found via another post on Reddit that having a Sonos speaker connected to the Ethernet backhaul port on RBS will cause issues. Removing the speaker from that port fixed my issues and all is working well now.
Apr 25, 2024Guru - Experienced User
Interesting. Glad you got it working. Thank you for letting us know. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
