Rain06
Jan 09, 2025Follower
Re: RBE971 Firmware Version 9.12.2.1 Issues
I still have the same issue. Latest firmware: V9.12.4.16_1.3.21 Does anyone know if there is a solution to remove the additional SSID...? Thank you.
- Jan 09, 2025
Latest FW is here:
Nothing we can do to remove the additinal SSID. Just avoid it for now. NG is aware of it. No idea IF or when it will be hidden. It's secured and can't be used.
Jan 09, 2025Guru - Experienced User
Latest FW is here:
