Saner
Apr 24, 2025Apprentice
Re: RBE971 reboots
I also have random reboots on 972, every 2-3 days. RBR971 is connected in AP mode to French provider Orange modem/router. 972 replaced 752 who never had same reboot issue during 2-3 years. Since I cha...
Apr 29, 2025Guru - Experienced User
Does the front LED on the RBR turn PINK or blink WHITE when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How is the RBR configured for AP mode? Dynamic or Static IP address configuration?
I presume the connection between the ISP router to the RBRs Yellow Internet port while in AP mode?
Is Guest Network enabled on the RBR?
Does the WAN status seen on the Show Stats button for Uptime show same value as the RBRs IP address/debug.htm web page for system uptime as well or do they differ?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
How many devices in total do you have connected all at once?
- SanerMay 02, 2025Apprentice
My network topology is :
- Router : Orange France Livebox 7
- Orbi 971R is configured in AP mode with Static LAN IP : 192.168.1.2 provided by the router Orange France Livebox
- ORbi 971R is connected to router Orange with CAT6 or 7 cable.
- 1x Orbi 970S with wireless backhaul and has static IP 192.168.1.3
- FW of both Orbi 971R and 970S is the lates PRD releas 9.12.5.3
- The LAN topology is +/- 40 devices with +/- 10 on 2.4 GHz, +/-25 on 5 GHz and on 3-4 on 6 GHz .(i.e. iPhone 15 Pro Max + 2-3 PCs)
- Guest Network Enabled or Disabled : Both cases tested and random reboots occurs on both
- IoT network is disabled
- Home is around 90 m2 with 1 R and1 satellite. The distance between R + S is around 10 - 12 m with 1 wall.
- IP randomizers of ALL connected devices are disabled.
When the Orbi RBE971 randomly restarts it is blinking white 3-4 minutes. And the unique satellite 970S is pink as it lost the connection with 971R.
When RBE971R is up again, the satellite takes +/-5 more minutes to became blue (from pink) and initially it is connected with 2.4Ghz wireless backhaul. After +/- 10 more minutes it reconnects to the 971R with 5GHz and 6 GHz backhaul.
Everything works fine until next random reboots.
NG Support already requested to switch the power adapters between Router and Satellite, change the power source on the wall and reset/reconfigure the router. Non of those actions did resolve the problem.
Today they called again following to this topic and they requested to capture logs.
- FURRYe38May 02, 2025Guru - Experienced User
- Orbi 971R is configured in AP mode with Static LAN IP : 192.168.1.2 provided by the router Orange France Livebox> Is the static IP address Set on the RBR for AP mode? What is the IP address subnet used on the Livebox 7? Does it use 192.168.1.1? And what is the Default IP address pool size of the Livebox 7? 192.168.1.2 thru .254?
- ORbi 971R is connected to router Orange with CAT6 or 7 cable. > CAT6A STP is recommended.
- 1x Orbi 970S with wireless backhaul and has static IP 192.168.1.3 > How is the RBS ethernet connected to the RBR? Directly behind the RBR or is there a LAN switch in between?
- Home is around 90 m2 with 1 R and1 satellite. The distance between R + S is around 10 - 12 m with 1 wall. > Does this still happen with the RBS turned OFF?
==> Static IP is configured only in the Orange Livebox's DHCP config.
MAC of RBR leased to 192.168.1.2 and MAC of RBS leased to 192.168.1.3
DHCP pool of router Livebox is from 192.168.1.2 to 192.168.1.253
==> RBS is not ethernet/cable connected. It is wireless backhaul between RBR and RBS. There is NOT any LAN switch at home. Orange LiveBox has 5 LAN port where only 1 is 10 GBit. This port connected to RBR. All devices at home are through WiFi. Ethermnet ports of Livebox + RBR + RBS are NOT used.
==> Never tried with RBR only mode. I need to use RBS to connect PCs at my home office room which is in the same room with RBS. Without RBS, the WiFi coverage is very low./quite unusable.
Below the basic logs, mostly disabled
Please change the DHCP pool on the Livebox to .100 to .250. Then set a static IP address configuration on the RBR in AP mode for 192.168.1.97
OK.
Test would be to only check to see RBR continues to reboot if RBS were turned off. Maybe try this near the time you think the RBR reboots.
That shows someting on the host router that is not getting to the RBR. RBR log shows internet is been disconnected. Something to check on the ISP router.
Someting else to try as well, try the RBR in router mode and use the ISP Routers DMZ for the IP address the RBR gets from the ISP Router while in router mode. See if RBR continues to reboot.
