Saner
Apr 24, 2025Apprentice
Re: RBE971 reboots
I also have random reboots on 972, every 2-3 days. RBR971 is connected in AP mode to French provider Orange modem/router. 972 replaced 752 who never had same reboot issue during 2-3 years. Since I cha...
May 02, 2025Guru - Experienced User
Saner wrote:
My network topology is :
- Router : Orange France Livebox 7
- Orbi 971R is configured in AP mode with Static LAN IP : 192.168.1.2 provided by the router Orange France Livebox> Is the static IP address Set on the RBR for AP mode? What is the IP address subnet used on the Livebox 7? Does it use 192.168.1.1? And what is the Default IP address pool size of the Livebox 7? 192.168.1.2 thru .254?
- ORbi 971R is connected to router Orange with CAT6 or 7 cable. > CAT6A STP is recommended.
- 1x Orbi 970S with wireless backhaul and has static IP 192.168.1.3 > How is the RBS ethernet connected to the RBR? Directly behind the RBR or is there a LAN switch in between?
- FW of both Orbi 971R and 970S is the lates PRD releas 9.12.5.3
- The LAN topology is +/- 40 devices with +/- 10 on 2.4 GHz, +/-25 on 5 GHz and on 3-4 on 6 GHz .(i.e. iPhone 15 Pro Max + 2-3 PCs)
- Guest Network Enabled or Disabled : Both cases tested and random reboots occurs on both
- IoT network is disabled
- Home is around 90 m2 with 1 R and1 satellite. The distance between R + S is around 10 - 12 m with 1 wall. > Does this still happen with the RBS turned OFF?
- IP randomizers of ALL connected devices are disabled.
Saner
May 02, 2025Apprentice
==> Static IP is configured only in the Orange Livebox's DHCP config.
MAC of RBR leased to 192.168.1.2 and MAC of RBS leased to 192.168.1.3
DHCP pool of router Livebox is from 192.168.1.2 to 192.168.1.253
==> RBS is not ethernet/cable connected. It is wireless backhaul between RBR and RBS. There is NOT any LAN switch at home. Orange LiveBox has 5 LAN port where only 1 is 10 GBit. This port connected to RBR. All devices at home are through WiFi. Ethermnet ports of Livebox + RBR + RBS are NOT used.
==> Never tried with RBR only mode. I need to use RBS to connect PCs at my home office room which is in the same room with RBS. Without RBS, the WiFi coverage is very low./quite unusable.
Below the basic logs, mostly disabled
- FURRYe38May 02, 2025Guru - Experienced User
Please change the DHCP pool on the Livebox to .100 to .250. Then set a static IP address configuration on the RBR in AP mode for 192.168.1.97
OK.
Test would be to only check to see RBR continues to reboot if RBS were turned off. Maybe try this near the time you think the RBR reboots.
That shows someting on the host router that is not getting to the RBR. RBR log shows internet is been disconnected. Something to check on the ISP router.
Someting else to try as well, try the RBR in router mode and use the ISP Routers DMZ for the IP address the RBR gets from the ISP Router while in router mode. See if RBR continues to reboot.
- SanerMay 04, 2025Apprentice
==> Similar approach has already been tested. DHCP pool has been changed to .10 to 1.200. RBR has static IP .2 and RBS .3, so outside of DHCP dynamic assignment range. Since last reboot thisi is the current config. DHCP range is from .10 to .200; but RBR rebooted again early this morning. .
==> I don't agree with that. The error "Internet disconnected" happens after RBR crash/restart and during the reboot. In the reboot process it says first "no internet" with the timestamp 2024 Nov 21, then it connects to the ISP router (internet connected) it syncro the time with NTP server and all logs are accurate. So this "internet disconnected" message is expected behaviour during the RBR restart.
==> This is not a usable workaround in my topology. Orange France force to use its own router Livebox to allow IPTV via its decoder Orange TV. If the IPTV decoder is not connected to Livebox, no tv at all.. I can't have 2 WiFi network with same SSID and 2 different DHCP servers / IP ranges.
==> Again as I said intially, before 972 I had 752 who was working without any issue since 2--3 years in AP mode with similar topology. Since I moved to 972, those random restarts happens and unfortunately as I have seen in the forum I'm not the only one. Or my 972 has a HW issue, or SW/FW. I saw that some people had new devices after RMAs, but I'm not sure if their problem is resolved after RMA....
- FURRYe38May 04, 2025Guru - Experienced User
You can use the ISP router in router mode along with the RBR i router mode. Just disable the wifi radios on the ISP router and use the DMZ on the router for the RBR. I've done this many times. Is a usable test just to check and see if the RBR continues to reboot.
I would recommend that you make contact with NG support regarding this.
