breaksfr123
Sep 19, 2024Guide
Re: RBR50 Satellite disconnects from router when using Ethernet port
I know this is an old thread, but I have exactly the same problem, i.e. I have sky q with one mini box and am trying to use a powerline adapter to connect to both the main sky q box and the sky q min...
Sep 19, 2024Guru - Experienced User
Seems like the power line adapters and any ethernet cabling in between the RBR and RBS need to be checked.
Consults the manufacturer of the power line adapters for support help and information regarding there product.
Swap adapters around.
Try the power line adapters while in same room with the RBR and RBS to check stability.
CAT6A STP cabling is recommended.
RBS if ethernet connected to the RBR have to be connected using one of the following configurations:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
breaksfr123
Sep 19, 2024Guide
Thank you for getting back to me. I do not have a ISP routr connected to the Orbi, rather I have an ONT connected directly to the Orbi, which is acting as router. So there are no antennas to disable. Cables are all CAT 6A and all brand new.
The configuration I have is Orbi router to TP link powerline to ethernet port downstairs and TP link powerline to satellite to ethernet port upstairs. I do not see why this is confusing the satellite and router, especially since it worked fine for a few days.
- FURRYe38Sep 20, 2024Guru - Experienced User
Possible some with with in the TP-Link adapters are causing problems. If the RBS works find directly connected to the RBR, then this points to the TP-Link adpaters not providing good services in between the RBR and RBS. There is some specific data flow that happens in between the RBR and RBS when ethernet connected. If this is blocked, then the RBS can not work right. You might try some NETGEAR branded power line adapters to see if this may help.
Possible some power line interferences in between the RBR and the in wall power as well. Could be something you have plugged in to the power on a wall out let that maybe causing noise on the line.
Try the RBS wirelessly connected to the RBR if it will connect OK.
