Billy1956
May 23, 2024Aspirant
Wired Backhaul ?
I upgraded to the RBE 971 with 2 RBE 970. I have Ethernet Wall Outlets. Router plugged into Arris S33 Modem. Both Satellites plugged into Wall outlets and into Router 2.5 . Web UI shows Wired. Not su...
May 23, 2024Guru - Experienced User
Are the RBS connected to Ports 2 and 3 on the RBR?
Another way to check this is to log into the RBS web page and look at the large wifi icon there, if the RBS are ethernet connected, this icon will show as Gray.
Also log into the RBRs web page and look at the Connected Devices page. Were the RBS are listed, you'll see a connection status. This will show as "Wired" here if the RBS are ethernet connected.
Billy1956
Yes the satellites are in ports 2 and 3. and say Wired in the web UI. Please bear with me I am not very Tech Savvy. So I should be looking at ports 2 and 3 TxPkts etc as the numbers for current backhaul and not the 3 last lines which spell out backhaul?
- FURRYe38May 23, 2024Guru - Experienced User
Correct.
- Billy1956May 23, 2024Aspirant
Thank You Sir. I pay for 1 Gig down and 40 MBS up and seem to be getting it. Would using a 10 gig switch(XS505m) and having the Satellites connected to the switch along with each Satellite connected to the wall plugs and the 10 gig port give me any benefits? Also how would you connect the Router to the Switch? I do not have Fiber. Thanks for your patience with me.
If the system is working currently with the RBS ethernet connected, adding a extra switch may not benefit you, only in that it would open up the ports used by each RBS and put the RBS all on the additional switch. Would be up to you.
