TOPS119
Jan 24, 2025Virtuoso
Reading of my log
Please explain my chart for me why is there so many zero on my sheet are these restarts ?
- Jan 25, 2025
1. the lan ones mean something isn't connected and transmitting data on those. Must only have something plugged into lan 1 and 2 (and lan 2 is just 100mbps link)
2. the backhaul tends to imply you're using a wired backhaul or have no satellites since nothings transmitting on them.
3. The 6ghz means you don't have anything connected to 6ghz.
4. Your 0 collisions means there hasn't been any traffic interference (good thing).
Nothing looks bad on that. Its all pretty standard.
FYI, thats you wan/lan port statistics, not the log 🙂
Jan 25, 2025Guru - Experienced User
- TOPS119Jan 25, 2025Virtuoso
Appreciate this reading where do I fine the log that shows how long I have been connected and disconnections ?
I have also notice that the 6ghz band only works with the router and not on the two satellite is this normal ?
- plemansJan 25, 2025Guru - Experienced User
what makes you think that?
I did the test so right now im right next to one of the satellites it only gives 5ghz when I go down stairs to the main router it switches to 6ghz
