TOPS119
Jan 24, 2025Virtuoso
Reading of my log
Please explain my chart for me why is there so many zero on my sheet are these restarts ?
- Jan 25, 2025
1. the lan ones mean something isn't connected and transmitting data on those. Must only have something plugged into lan 1 and 2 (and lan 2 is just 100mbps link)
2. the backhaul tends to imply you're using a wired backhaul or have no satellites since nothings transmitting on them.
3. The 6ghz means you don't have anything connected to 6ghz.
4. Your 0 collisions means there hasn't been any traffic interference (good thing).
Nothing looks bad on that. Its all pretty standard.
FYI, thats you wan/lan port statistics, not the log 🙂
Jan 25, 2025Guru - Experienced User
TOPS119
Jan 25, 2025Virtuoso
I have also notice that the 6ghz band only works with the router and not on the two satellite is this normal ?
- plemansJan 25, 2025Guru - Experienced User
what makes you think that?
- TOPS119Jan 25, 2025Virtuoso
I did the test so right now im right next to one of the satellites it only gives 5ghz when I go down stairs to the main router it switches to 6ghz
Just because it didn't connect to 6ghz, doesn't mean it isn't broadcasting. your device chooses whether to connect to the 5ghz or the 6ghz (or 2.4). something in its settings might be saying to connect to the 5.
You can always install a wifi scanner that detects 6ghz to check to see if its broadcasting.
