C702
Jan 05, 2025Aspirant
Recent experience Orbi 970 with At&t gateway
Hi With my AT&T gateway, the Orbi router will have to be set up in AP mode - which seems like it is basically functioning as a satellite. If I’m covering a 3 story home -about 10,000 sq ft, total, ...
Jan 05, 2025Guru - Experienced User
MESH is more designed to be a extender system and has the ability for backhaul support while still giving front haul, user connectable wifi signals and also provide MLO support for your devices that support MLO/WiFi7 and integrates with in itself or user visibility to see what is connected to each AP and check on status.
30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
- C702Jan 05, 2025AspirantThank you for your reply. Unless I’m mistaken, It sounds like I’d be spending substantially more but possibly not gaining enough benefit to justify the expenditure - especially given my primary workspace is next to the router/gateway. True?
- FURRYe38Jan 05, 2025Guru - Experienced User
I'd probably go with a current Orbi AX or AXE system.
