C702
Jan 05, 2025Aspirant
Recent experience Orbi 970 with At&t gateway
Hi With my AT&T gateway, the Orbi router will have to be set up in AP mode - which seems like it is basically functioning as a satellite. If I’m covering a 3 story home -about 10,000 sq ft, total, ...
C702
Thank you for your reply. Unless I’m mistaken, It sounds like I’d be spending substantially more but possibly not gaining enough benefit to justify the expenditure - especially given my primary workspace is next to the router/gateway. True?
Jan 05, 2025Guru - Experienced User
I'd probably go with a current Orbi AX or AXE system.
