booclay
Jun 28, 2024Tutor
Replacing Quickline FWA router (Zyxel EX3301-T0) with Orbi R970
Hi all, I've just had Quickline FWA installed at my house (UK), they use their own 5G network. They installed the following: Zyxel NR7101 installed outside Zyxel EX3301-T0 router inside POE...
Jun 28, 2024Guru - Experienced User
Your wanting to replace the ISP Zyxel EX3301-T0 router inside with the Orbi system?
You'll need to make contact with the ISP and have them help you to ensure any ISP configurations are correct and correctly put to the Orbi router.
The outside Zyxel NR7101 may need to be power cycled after the ISP router is disconnected and the Orbi router is connected and configured.
Can also try the ISP router with it's wifi disabled and the Orbi connected to it and use the ISP routers DMZ for the Orbi router.
booclay
Jun 28, 2024Tutor
Hmmm, this is interesting. If i did your 2nd solution would I get any downsides, connecting the orbi to their router, like double NAT?
I may have to go this way because Quickline helped for a bit and then just stopped and said, if its not working, then that's a you problem (but in a kind of nicer way 🙂
Cheers
