wRiNkLe_sTiCk
Oct 29, 2024Apprentice
Router upgrade to Wifi7
Thinking of upgrading my 850 series wifi6 mesh system to the new 970 series wifi7 mesh system. I have lots of IoT devices (currently on my home network) that I am not looking forward to having to reco...
Oct 29, 2024Guru - Experienced User
The 850 is a pretty rock solid series. What benefit do you anticipate getting going to the 970 series (other than 6ghz)?
Just curious as that's a significant expense for not a whole lot of performance improvement.
- wRiNkLe_sTiCkOct 30, 2024ApprenticeTrue… Other than a couple issues not related to hardware I have loved my 850’s. I guess it’s just my desire to have the latest technology. I’ll probably wait for them to offer a decent discount before pulling the trigger.
- plemansOct 30, 2024Guru - Experienced User
Or even check into the 770 series. Its triband and if you can hardwire them in, you'll get the same benefits. I've used both 970 and 770 and with the 770 series hardwired with a 2gig connection, I can max out the 2 gig without issues.
