1Robert
Oct 14, 2026Aspirant
satellite turning off the wifi when connected to Ethernet
Having a similar issues on my 871 with the satellite turning off the wifi when connected to Ethernet. I have them in AP mode, current firmware, reset thousands of times, set the units up within 10 f...
Oct 15, 2026Guru - Experienced User
Does the one Ethernet RBS work correctly if not ethernet connected and just wirelessly connected to the RBR?
How is the RBR configured for AP mode? Dynamic or Static?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How is the one RBS ethernet connected to the RBR? Directly behind the RBR or is there a LAN switch in between?
What CAT# LAN cable are you using? CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
