Orbidude
May 31, 2024Guide
Should I get the Orbi 970 series?
Hi, I currently have the Orbi 850 series (Router + 2 satellites). I live in a 3500 sq foot house). I keep the router upstairs and the 2 satellites are downstairs at opposite sides of the house. I...
- May 31, 2024
The existing Orbi 850 supports WiFi6 (not WiFi6E or WiFi7). Of the 35 devices on the network, how many support 6E or 7? (my guess is "under 3, if any at all") Existing devices which are not capable of 6E or 7 will gain nothing from the 971 product. If the actual load on the network is small, even more capable devices will not appear to be any faster. (how fast can an HD video stream? If a web page loads in 2.3 seconds insteadof 2.6 seconds, will you notice?)
WiFi8 is a total pipe dream at this point:
https://www.everythingrf.com/community/what-is-wi-fi-8
After it comes out, it may take years before a significant number of actual devices become available which can take advantage of it.
CrimpOn
May 31, 2024Guru - Experienced User
- OrbidudeMay 31, 2024Guide
Thank you CrimpOn. I guess I’ll stick with the current 850. 😊
By the way, how do I know if my devices support 6E or 7?
- CrimpOnMay 31, 2024Guru - Experienced User
The easiest way is to look up the official specs on the web. For example, on the Apple web site, the iPhone 13 has these specs:
iPhone 14 shows this:
iPhone 15 shows:
Thus, there is no existing iPhone that supports WiFi6E or WiFi7.
Samsung has some phones that do.
I see. Thanks for the info.
Reading the specs for the 970, it says: WiFi 7 delivers 2.4x faster speeds than WiFi 6.
I won’t benefit unless the devices are 6E or 7, correct?
- FURRYe38Jun 01, 2024Guru - Experienced User
Just curious, what FW version do you have loaded on your 850 series?
- OrbidudeJun 01, 2024Guide
I’m using firmware v7.2.6.31_5.0.24
My initial question whether to get the 970 or not was based on my FaceTime freezing up every now and then and I’m 15 feet from a satellite. I was just wondering if getting the 970 would help that.
Thanks!
