Orbidude
May 31, 2024Guide
Should I get the Orbi 970 series?
Hi, I currently have the Orbi 850 series (Router + 2 satellites). I live in a 3500 sq foot house). I keep the router upstairs and the 2 satellites are downstairs at opposite sides of the house. I...
- May 31, 2024
The existing Orbi 850 supports WiFi6 (not WiFi6E or WiFi7). Of the 35 devices on the network, how many support 6E or 7? (my guess is "under 3, if any at all") Existing devices which are not capable of 6E or 7 will gain nothing from the 971 product. If the actual load on the network is small, even more capable devices will not appear to be any faster. (how fast can an HD video stream? If a web page loads in 2.3 seconds insteadof 2.6 seconds, will you notice?)
WiFi8 is a total pipe dream at this point:
https://www.everythingrf.com/community/what-is-wi-fi-8
After it comes out, it may take years before a significant number of actual devices become available which can take advantage of it.
Orbidude
May 31, 2024Guide
Thank you CrimpOn. I guess Iâll stick with the current 850. đ
By the way, how do I know if my devices support 6E or 7?
CrimpOn
May 31, 2024Guru - Experienced User
The easiest way is to look up the official specs on the web. For example, on the Apple web site, the iPhone 13 has these specs:
iPhone 14 shows this:
iPhone 15 shows:
Thus, there is no existing iPhone that supports WiFi6E or WiFi7.
Samsung has some phones that do.
- OrbidudeMay 31, 2024Guide
I see. Thanks for the info.
Reading the specs for the 970, it says: WiFi 7 delivers 2.4x faster speeds than WiFi 6.
I wonât benefit unless the devices are 6E or 7, correct?
