kingharrison
Mar 14, 2024Aspirant
Slack Causes Constant Disconnects While in Huddle (video call)
I am on the latest firmware of 9.11.1 and I am having a challenge where Slack Huddles (video calls) constantly drop and then reconnect. Anyone else experience this?
Mar 14, 2024Guru - Experienced User
This the only app this happens with?
Does this happen with other devices?
Something to to ask the Mfr of this app about.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Try with SIP APG enabled. Under Advanced Tab/Setup/WAN Setup.
