BigDaveT
Aug 06, 2024Aspirant
slow download speeds on LAN ports ORBI 971
I've was using my ORBI 971 with 2 x 970 satellites for some time with my old provider (BT). My old setup was BT homehub 2 with 900Mbps download and 115Mbupload with Netgear Orbi setup in Bridg...
BigDaveT
Hello,
thanks for everyone's replies.
The ISPs ONT has a single 10Gbps copper port which connects to the 10Gbps Internet port on the RBE971. There is no ISP router in between the ONT and the RBE971. I do not have access to the ISPs ONT. The RBE is setup as the Internet router with IP address and gateway setup on it and that part works fine.
I'm using the RBE971 as a wireless back haul to the satellites but this isn't the issue here.
The issue i have is with directly connected wired devices to the LAN ports of the RBE971, wireless speeds are absolutely fine.
Thanks
Dave
Aug 06, 2024Guru - Experienced User
Your best option will be to make contact with NG support.
