FrankDH
Nov 25, 2024Aspirant
Slow Wired Speeds for Orbi 770
Got a new Orbi 770 Mesh Network with 3 Satellites. The output of the wired 2.5 GB ports is around 100Mbs. Received a replacement router from Netgear. Same problem. My router speed tests from the Or...
Nov 25, 2024Guru - Experienced User
What wired devices are you connecting to the RBR unit? Brand and model.
Does this happen with any ethernet device?
Ensure the devices are connecting at 1000Mpbs to the back of the RBR. Check this by logging into the RBRs web page and navigate to the Advanced tab then select Show stats. Look at the LAN ports listed here and see what the connection rate is seen here with the device connected to the LAN ports.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- FrankDHNov 25, 2024Aspirant
I have tried my Imac and and numerous 1 gb Apple tvs, plugged directly into the router, The wan shows 2500 full and the lan ports show 1000 full.
I have the lastest firmware juts released in the last few days installed. I have tried it with Armour on and off.
