FrankDH
Nov 25, 2024Aspirant
Slow Wired Speeds for Orbi 770
Got a new Orbi 770 Mesh Network with 3 Satellites. The output of the wired 2.5 GB ports is around 100Mbs. Received a replacement router from Netgear. Same problem. My router speed tests from the Or...
CrimpOn
Nov 25, 2024Guru - Experienced User
FrankDH wrote:
around 100Mbs.
Details are important. "just under 100Mbps", such as 92Mbps or 94Mbps is often a sign that the Orbi LAN port and device Ethernet port have negotiated a speed of 100Mbps/Full Duplex. "just over 100Mbps", such as 102Mbps are an indication that this is not the problem.
FURRYe38 's advice to check the Show Statistics information is the correct first step.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
This is for nighthawk but works the same on orbi and will display those ethernet connections
