FrankDH
Nov 25, 2024Aspirant
Slow Wired Speeds for Orbi 770
Got a new Orbi 770 Mesh Network with 3 Satellites. The output of the wired 2.5 GB ports is around 100Mbs. Received a replacement router from Netgear. Same problem. My router speed tests from the Or...
CrimpOn
Nov 25, 2024Guru - Experienced User
FrankDH wrote:
around 100Mbs.
Details are important. "just under 100Mbps", such as 92Mbps or 94Mbps is often a sign that the Orbi LAN port and device Ethernet port have negotiated a speed of 100Mbps/Full Duplex. "just over 100Mbps", such as 102Mbps are an indication that this is not the problem.
FURRYe38 's advice to check the Show Statistics information is the correct first step.
FrankDH
The highest download speed i ever got was 256 mbs and lowest 86 mbs.
- FURRYe38Nov 25, 2024Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Check with the wired PC connected to the ISP modem, what do you see there?
- FrankDHNov 25, 2024Aspirant
I am using an Netgear Nighthawk CM 2000 cable modem for Comcast 1.2 Gbs service. The Orbi app speed test showw the modem is delivering 1.4 Gbs to the router.
Just check with a PC connected to the back of the CM modem.
Then also speed test with Ooklas installable speed test app installed on the PC.Try a different PC to compare results.
