jjp22
Mar 21, 2026Tutor
Sonos and Printer and Orbi 870 mesh
My problems with the Orbi 870 mesh system continue. My router and one satellite are currently working. However I have recently been experiencing issues with my connection to Sonos arc and Move2 and ...
CrimpOn
Mar 21, 2026Guru - Experienced User
Printing from an iPhone can be done several ways. Are you using AirPrint or the HP printer driver?
Did the iPhone ever print on this HP printer?
- jjp22Mar 23, 2026Tutor
Yes. Before I got this orbi 870, I had no problems printing from iPhone to HP printer. Today it finds the printer.
- FURRYe38Mar 23, 2026Guru - Experienced User
What channels are you using?
What model# is this printer?
Something I do with my 870 series, configure a smaller default DHCP IP address pool size. Gives me room for additing static IP addressed devices outside of this pool range. Something I do for my two printers that when I use my 870 series, works find. Though my printers are only ethernet based. No Wifi printers. Also have NAS and controlers that are set for static IP addresses on these devices as well.
Are all these devices on the Main WLAN or some on the IoT network?
What iOS version is your phone using? 26.3.1 recent released.
Be sure to disable any MAC Address randomizers on phones and pads while at home:NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
The more you can give feedback on this, the better chance we might beable to find a resolution on this.
