RBster
Mar 27, 2024Aspirant
SSID broadcast
Hello I've noticed an unknown SSID being broadcast when the RBE971 is online. I did not initiate this and have disabled Guest network and IoT network. The name is NTGRBH_9xxxxxxxxx Any idea what ...
- Mar 27, 2024
Its the wireless backhaul. On prior versions the backhaul ssid was hidden. I didn't ever get a response on why they didn't do that on this version
RBster
Thanks for the fast response and clarification of this. Would be great if one of the tech guys from Netgear could pick this up and fix it.
Mar 27, 2024Guru - Experienced User
It's a known issue. Not sure if or when NG will fix it. They are ware of it.
- CrimpOnOct 30, 2024Guru - Experienced User
Yes, the original RBR50 Orbi still has the option to enable/disable broadcast of the SSID on the 2.4G and/or the 5G user channel:
This product is officially "End of Service", with the last firmware release in Feb, 2023.
- FURRYe38Oct 30, 2024Guru - Experienced User
That pertains to the front Wi-Fi signal and only on Orbi AC systems. OP is asking about this backhaul SSID that's only seen on Orbi BE systems and is a known issue that NG is aware of. No time frame on if or when this will be fully addressed by NG.
