ultifisher
May 22, 2026Aspirant
Terrible Support, many problems
I have had an Orbi RBE871 and 2 RBE870 satellites for almost a year. They have never worked all that well, especially for cell phone calls via Wi-Fi, which we need because we have almost no local cel...
ultifisher
May 23, 2026Aspirant
Platforms: Apple iPhone and Windows 11
Firmware: V10.5.20.4_1.3.5
Modem is Netgear CBR750 with V4.6.14.4_2.3.12 in Bridge mode (which the helpdesk configured) (not that whatever modem and service provider should matter for this problem).
IPv6 is enabled (again... not that this should matter)
ISP is Comcast xFinity (...not that this should matter)
Home is 3000 sqft
Distance between router and satellites is about 80-100 feet.
MAC Address is not random on several of the devices that used to show up but do not any longer.
May 24, 2026Guru - Experienced User
ultifisher wrote:Distance between router and satellites is about 80-100 feet.
Rather far.
Try turning off the satellites and measure the wifi speed using your phone at the two satellite locations. (You can use the free Ookla speedtest app for this - disable mobile data during the test).
The satellites need a solid wifi connection to the router in order for the mesh to work well (assuming you are not using ethernet backhaul).
