skooter25
Dec 26, 2023Aspirant
The router loses connection to the internet
I have been dealing with this same issue for 2 weeks now and nothing has changed. My system will be connected to the internet on the "main" network and the "guest" network will lose internet connect...
Dec 26, 2023Guru - Experienced User
Does the front LED turn PINK when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
skooter25
Monoprice Cat 8 between router and orbi.
Google Fiber 8gb service GFRG300.
1 satellite
2700sqft home
Lose of internet on main happens wired or wireless. Guest is wireless.
1 satellite
2700sqft home
- FURRYe38Dec 26, 2023Guru - Experienced User
Is the CAT cable UTP or STP cabling. STP cabling is recommended here.
30 feet distance between RBR and RBS is recommended as well.
- skooter25Dec 26, 2023Aspirant25/40GBase T cat8 2000MHz PIMF not sure what UTP or STP is. As for the 30 ft between, they are in the same place my last 2 generations of ORBI were without any issues.
STP is recommended for any connection rates beyond 1Gb. Especially for multi gig connections.
Look it up.
Doesn't tell us the distances between them. There are good reasons for these quesetions. Hard to help out if we don't get feedback.
