yolo1010
Sep 17, 2025Aspirant
The satellite in question is one floor below ~25 feet away
Curious if anyone still gets this issue. I have orbi 870. The satellite in question is one floor below ~25 feet away. I know the suggestion is +30 but this is where it has to go for now. It oscillates between good and poor although no noticeable performance issues when it says poor. That said, it's driving me crazy!
I don't see with my 870 series online currently. RBS wirelessly connected. Most any distances less than 30 feet in between the RBR and RBS, you may see issues. 25 feet or less is too close in between the RBR and RBS.
What is the size of the home in sq feet?
Only one RBS or more then one?
What FW version are you using?
- yolo1010Aspirant
5,200 sq feet home. RBR on 2nd floor. RBS #1 on 1st floor one floor below, a little less than 30 feet away. RBS #2 on third floor 40+ feet away from RBR, no issues.
Firmware V10.5.19.4_1.1.27
So might try RBS1 placement and adjust it out a bit and see if the status stops changing or keeps this going...
Often there are "things in the walls", such as HVAC ducts, chimneys, etc. which can affect the WiFi connection between router and satellite. It might be worth experimenting with moving the router & satellite slightly to different positions to see if one is more stable.
It might be helpful to lean more about WiFi coverage in the house. There are "Heat Map" applications for many platforms which allow the user to walk around and record WiFi signal strength at various places. After being told, "the WiFi is not very good in the bedroom", I installed WiFi Heat Map (by Webprovider) on an Android tablet. Walked around the upstairs and recorded this:
Oh, dear. GREAT WiFi signal in the room where the Spectrum modem and WiFi router are located. (This was install SO many years ago!) After about 36 ft. and four walls, the signal had dropped to -76dB. Installed an Orbi satellite in the bedroom and did another "walk":
No more complaints!
p.s. I find the ENORMOUS X's marking where readings were taken annoying. But, it is a free app.
