ibagoalie
Oct 13, 2023Tutor
Thinking of adding a third satellite
I just got the Orbi 971 and put the router next to the cable modem in the first floor front bedroom (my house is a smallish ranch 1700 SqFt with basement). The satellite I put in the basement. I get...
- Oct 14, 2023
Problem solved!! Moved my Firecube to the problem TV in Master Bedroom and because it sits out more exposed, it is getting a strong signal, so 4K is supported. And best of all, much cheaper than an additional Satellite!! Thanks all for your tips.
Oct 13, 2023Guru - Experienced User
Can you log into your tv or router and check if the tv is connected to the 2.4ghz or the 5ghz?
200+ mbps should be plenty for streaming 4k as it only takes about 25-40mbps to stream 4k.
But 2.4ghz might link at 200+ and not be able to achieve those speeds because its a slow network and sensitive to interference.
5ghz should have no problem saturating a 4k show/movie at those link speeds.
ibagoalie
Oct 14, 2023Tutor
- plemansOct 14, 2023Guru - Experienced User
glad its working well for you! A much much cheaper option
- FURRYe38Oct 15, 2023Guru - Experienced User
Enjoy. 📡
