Majmoz
Apr 06, 2025Aspirant
Unable to get VPN setup on Orbi Router RBE771
I have been trying to setup the VPN on the router per the instructions given. Now I getting the following from the OpenVPN config log: TCP/UDP: Incoming packet rejected from [AF_INET]..., expected pe...
- Apr 07, 2025
Sorry. I was confused. Was not aware that Netgear offers a VPN service. Bitdefender Armor includes a VPN feature. I have never enabled Armor. ("Free Trial" triggered a thought, "and then it costs money".)
Most questions on the Community Forum about VPN are typically about:
OpenVPN hosted by the Orbi router. The feature found on the Orbi web interface, Advanced Tab, Advanced Settings. This feature allows customers to access their local network from the internet using OpenVPN Client software loaded on a computer or mobile device. Instructions and configuration files are downloaded from the Orbi router. This feature does not support connecting to the router from within the LAN.
OpenVPN Client. Rather than install VPN software on each of their devices, some users would rather that their WiFi router act as a VPN Client which bundles connections from every device into a VPN tunnel to a VPN provider on the internet. (NordVPN, ExpressVPN, etc. etc.) There are several brands of WiFi router which provide this feature, but Netgear routers do not.
Running VPN client software on customer devices. This is when users have signed up with a VPN host service (NordVPN, ExpressVPN, etc.) or have been directed to use a VPN to access their corporate or organization network. The Orbi WiFi router has nothing to do with this activity.
Majmoz
Apr 07, 2025Aspirant
This is a client setup using Netgear as the VPN. OpenVPN is merely facilitating it and does not provide a VPN. All of the config files and instructions were provided by Netgear via a download link. I tried to connect to OpenVPN using 5G and got the same result. However, I can connect to the Orbi RBE771 router without issue.
CrimpOn
Apr 07, 2025Guru - Experienced User
