OlaGarp
Apr 03, 2025Aspirant
Unable to install iPhone apps using Orbi RBE771
When connected to the RBE771 wifi, I'm unable to download and install iPhone apps. As soon as I turn the wifi off the mobile, the apps download and install. Appreciate any help Ola
MiniTuna
Apr 03, 2025Guide
Do you happen to be using AdGuard DNS or a similar service? For me, that was the cause of App Store brokenness / slowness so I switched to NextDNS. It's also possible your ISP is at fault. Try first by switching your device to known "clean" DNS servers like 1.1.1.1 or 8.8.8.8.
- OlaGarpApr 06, 2025Aspirant
Hi
Not using AdGuard DNS or a similar service
Cheers
Ola
- CrimpOnApr 06, 2025Guru - Experienced User
What happens when the Orbi DNS is changed from "Get automatically from ISP" to Google (8.8.8.8) of CloudFlare (1.1.1.1)?
- donawaltApr 06, 2025Hero - Experienced User
Yes, try 8.8.8.8 or 1.1.1.1 for your DNS. To be safe, 'Forget' your WiFi network and rejoin it after you change DNS.
I assume the WiFi is working fine otherwise - speeds good, no connectivity issues with other apps or browsers? Also, I assume the 770 router is set to router mode not access point?
Go to https://apps.apple.com on your iPhone's browser - this is the Apple app server IP address. Does it load?
Assuming yes, some other things to check (test after each change):
- As Furry said, turn off Armor and Parental Controls.
- Is low data mode turned on, on your iPhone? Try it with that off - settings > wifi > (your WiFi SSID) > toggle Low Data Mode OFF
- WiFi Assist can cause issues if the WiFi is flaky - turn it off for a test: Settings > Cellular > Wi-Fi Assist
- Are you using a VPN on your iPhone? Some, especially if they do ad-blocking, can block Apple servers. Turn off your 3rd party VPN if it has a separate settings/config. Also see if Netgear's VPN is off: login at 192.168.1.1 > Advanced tab > Advanced > VPN Service
- Is Private Relay on, on your iPhone? Same as VPN - Test with it off: Settings > iCloud > Private Relay
- Are you using the Netgear router's Traffic Meter? It's possible it could be limiting traffic. Test with it off: login at 192.168.1.1 > Advanced tab > Advanced > Traffic Meter.
- On your iPhone, reset your network settings - Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings. The only risk on this is it will forget any networks/passwords, you will have to reenter them next time you log in. But resetting it can clear up a lot of network issues for an iPhone.
Good luck - keep us posted!
