OlaGarp
Apr 03, 2025Aspirant
Unable to install iPhone apps using Orbi RBE771
When connected to the RBE771 wifi, I'm unable to download and install iPhone apps. As soon as I turn the wifi off the mobile, the apps download and install. Appreciate any help Ola
Apr 03, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Who is your ISP service?
Does this happen with the RBS turned OFF?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, IPv6, Smart Parental Controls, Traffic Meter.
OlaGarp
Apr 06, 2025Aspirant
Hi
Firmware: V10.5.13.1_2.2.34
Modem: NBNCo
Cable: CAT6
ISP: Internode
What is RBS?
Tested with and without WiFi Private IP address
Not using iCloud Relay
Not using Armor, IPv6, Smart Parental Controls, Traffic Meter.
Cheers
Ola
- FURRYe38Apr 07, 2025Guru - Experienced User
Let us know if changing the DNS recourse helps.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There should be a model# on the sticker. Trying to check for a built in router here.
RBS = Satellite.
OlaGarp wrote:
Hi
Modem: NBNCo
Cable: CAT6
ISP: Internode
What is RBS?
Cheers
Ola
- OlaGarpApr 13, 2025Aspirant
The router is provided by Australia's National Broadband Network. It's a white-labeled router. It's fitted in a case and I'm not taking it apart, risking damaging the fiber-optic cable.
I don't think this issue has anything to do with my ISP or the route but all about the Orbi. I had none of these issues before Xmas when I was still running a NetGear R6300v2. I think I will kick it into gear again to prove if it's wifi or router/ISP.
Ola
- FURRYe38Apr 13, 2025Guru - Experienced User
Let us know if changing the DNS recourse helps. Try using Cloudfare or Quad9.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Call up the ISP and ask them for this information.
