OlaGarp
Apr 03, 2025Aspirant
Unable to install iPhone apps using Orbi RBE771
When connected to the RBE771 wifi, I'm unable to download and install iPhone apps. As soon as I turn the wifi off the mobile, the apps download and install. Appreciate any help Ola
OlaGarp
Apr 06, 2025Aspirant
Hi
Firmware: V10.5.13.1_2.2.34
Modem: NBNCo
Cable: CAT6
ISP: Internode
What is RBS?
Tested with and without WiFi Private IP address
Not using iCloud Relay
Not using Armor, IPv6, Smart Parental Controls, Traffic Meter.
Cheers
Ola
Apr 07, 2025Guru - Experienced User
Let us know if changing the DNS recourse helps.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? There should be a model# on the sticker. Trying to check for a built in router here.
RBS = Satellite.
OlaGarp wrote:
Hi
Modem: NBNCo
Cable: CAT6
ISP: Internode
What is RBS?
Cheers
Ola
- OlaGarpApr 13, 2025Aspirant
The router is provided by Australia's National Broadband Network. It's a white-labeled router. It's fitted in a case and I'm not taking it apart, risking damaging the fiber-optic cable.
I don't think this issue has anything to do with my ISP or the route but all about the Orbi. I had none of these issues before Xmas when I was still running a NetGear R6300v2. I think I will kick it into gear again to prove if it's wifi or router/ISP.
Ola
- FURRYe38Apr 13, 2025Guru - Experienced User
Let us know if changing the DNS recourse helps. Try using Cloudfare or Quad9.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Call up the ISP and ask them for this information.
- OlaGarpApr 20, 2025Aspirant
Hooked up my old NetGear R6300v2 and it worked like a dream. Same external router, same ISP, same DNS, same mobile. Installed the mobile app as soon as I selected it the app store.
Why does the Orbi block the iPhone app install?
