Chuck_M's avatar
Chuck_M
Mentor
Jan 15, 2025
Verizon fiios and Orbi 970 experience
I have been working on a project to use a pfSense equipped appliance as a robust router behind a Verizon Gxxx router (bridged) with an Orbi RBE970 in AP mode delivering WIFI services.
Has anyone had experience doing this? I have seen what appears to be compatibility issues and would like to collaborate on specific configurations and best practices.
  • I have been working on a project to use a pfSense equipped appliance as a robust router behind a Verizon Gxxx router (bridged) with an Orbi RBE970 in AP mode delivering WIFI services.
    • McLong's avatar
      McLong
      Luminary
      Hi Chuck,
      In early December, I switched to the OPNsense firewall and router, using AP 971 and 970. The limited QoS settings and noticeable buffer lag during conference calls prompted this change. I'm still fine-tuning the setup, but feel free to DM me anytime.
      Edit.. using Comcast gateway in bridge
      • Chuck_M's avatar
        Chuck_M
        Mentor
        Thanks!  I will definitely take you up on this!   Did you remove totally the verizon router or do you have it in bridge mode?
        Will send you a PM asking you for details!
        Appreciate it.
    • plemans's avatar
      I've debated on setting up a pfsense setup but have only went so far as a pihole that I occasionally set to manage dhcp. To many times I'm testing systems and need the system managing everything.
      • Chuck_M's avatar
        Chuck_M
        Mentor
        I have a network appliance running pfsense, a mini running pinhole for dns and dhcp, and orbi 971 in ap mode. Works great
