dasander
Jul 23, 2025Guide
VPN configuration
Has anyone been successful in getting openvpn to work with this router?
CrimpOn
Jul 23, 2025Guru - Experienced User
It has been several hours without a response. Perhaps it might be worth:
- Posting in the regular Orbi WiFi7 forum:
Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities - Or describe the specific issue that has come up.
i.e. how is it not working?
dasander
Jul 25, 2025Guide
All I can get is a timeout trying to connect, I have tried multiple config setups. I have used this on prior routers so I know it works and how to manage the config files.. but with this router I get nothing.
