lkroeker
Oct 22, 2024Aspirant
WAN port needs to use VLAN 35 for all traffic going in and out.
The menu for configuring VLAN tagging is a little unclear, I only need to tag traffic going in/out from the WAN connection, but I can't see if that's the default function or if it's adding that taggin...
CrimpOn
Oct 22, 2024Guru - Experienced User
Could you please post a link to the ISP instructions regarding VLAN?
The reason I ask is that the most common ISP use of VLAN is specifically for IP TV, not for general internet traffic. (i.e. exactly the opposite situation) Orbi routers provide this IP TV capability.
- lkroekerOct 22, 2024Aspirant
- CrimpOnOct 22, 2024Guru - Experienced User
Thanks for that link to the Bell Community Forum. Just to clarify, is the goal to:
- Connect the Orbi 970 system to the Bell Home Hub 3000, or
- Remove the Bell Home Hum 3000 entirely and connect the Orbi router directly to....?
- lkroekerOct 22, 2024AspirantThe home hub has been disconnected for a while now. I've used it successfully with another router, but keep trying to get this system to work based on the promised awesomeness. Lol.
Basically there's a fiber to lan interface that connects via ethernet to the wan port and the router connects/logs-in via PPPoE. (This was broken at first with these units as well, but thankfully they fixed it)
