zaguama
Mar 06, 2024Aspirant
Watch out with firmware 9.11.1.1
Just updated to firmware 9.11.1.1 and the algorithm decided to change from my daisy chain topology to star topology for some reason. I did a hard reset on the satellites and still didnt make a diff...
- Mar 06, 2024
How is your RBS placed and distances from the RBR?
You'll need to factory reset the RBR along with the RBS to check this after v9.11.1.1 is loaded. You can't just reset the RBS. Something may have changed in new FW that needs to be cleared out after loading new FW. NOTEs suggest doing this, even if a power cycle on the RBR and RBS fail to resolve issues seen after new FW is loaded.
Mine show star formation after this version was loaded.
Mar 06, 2024Guru - Experienced User
