TOPS119
Jan 19, 2024Luminary
When connected wired backhaul I notice
Basically I notice when connected wired some times the satellites are in a line in the app and some times it shows in the natural triangle formation is this natural or anybody knows the difference ? ...
Jan 19, 2024Guru - Experienced User
How are the RBS ethernet connected to the RBR? Directly behind the RBR in parallel or is one RBS connected to the other RBS?
Any LAN switches in between the RBS and RBR? Brand and model please if present.
Ethernet connected RBS should be connected using one of the following methods:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰
What ports are you using on the RBS to connect them? The Multi Gig port or the 1G ports?
What CAT# lan cable are you using? CAT6A STP is recommended for mutli gig port connections past 1Gb.
What FW version is loaded on the system?
TOPS119
Running the latest firmware think im using cat 5, no switch is involve.
- FURRYe38Jan 19, 2024Guru - Experienced User
CAT5 isn't rated for 1000Mb.100Mb, CAT5e is. However since the ports support speeds beyond 1Gb, It's recommended to use CAT6A STP cabling.
- TOPS119Jan 20, 2024Luminary
My speeds are nowhere 1gb I only have 250mbps internet so I don't think my cat 5 should be an issue
So I plugged them all out but before I did I notice the third satellite that was slower has a different connection id from the other satellite, when I do wireless they have the same id, I think that might be where the issue is coming from
