Yld2rob
Nov 09, 2023Luminary
Where is Wi-fi 6 and 7 on the 970?
So it's been 24 hours since I installed the Orbi 970 system. I have a couple of Wi-Fi 6 and one Wi-Fi 7 devices. When I go into the Orbi web page and look at connected devices, those devices show con...
- Nov 09, 2023
I just figured out the issue. Turning off wi-fi private IP, limit IP tracking, and iCloud on the iPhone 15 fixed the issue. it is now showing connected at 6GHz. As far as the other wi-fi 7 device the OnePlus Open, I turned off randomized MAC address. That device now displays connected at 5GHz+6GHz. Hopefully this will help someone else with this issue.
Yld2rob
- FURRYe38Nov 09, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - SagnewNov 09, 2023Apprentice
Is Wifi 7 actually working at the moment? From my understanding there is no such thing as a 7Ghz signal but rather an aggregated 5Ghz + 6Ghz connection, so it certainly sounds like it is working?
I assumed Wifi 7 was primarily for MLO / backhaul
Correct.
Also one can enable 240Mhz channel with for BH as well. Though system may only use 160Mhz depending on signal quality between RBR and RBS and building materials in between. WiFi 7 is a mode, not a frequency: https://www.wiisfi.com/
