brianld
Oct 19, 2023Apprentice
White LED always on
I set up my Orbi 973 system yesterday, which for the most part went smoothly. Strangely though, the LED at the bottom of the main router is solid white, and has been that way since setup. My 960 seri...
- Oct 20, 2023
Update on this:
I powered off the ONT for 15 mins, then powered on. Rebooted router. White LED remained on (solid).
After I went through a complete reset and setup of the Orbi from scratch again (see my other post on the admin portal issue), the white LED is no longer on! Seems that somehow the router was in a funky state or perhaps thought setup wasn't complete.
brianld
Interesting. Ok, I'll try that when I get a chance.
brianld
Oct 20, 2023Apprentice
Update on this:
- FURRYe38Oct 20, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
