phillipsaz
Jan 27, 2025Aspirant
WiFi 7 and iPhone 16 Pro Max along with wireless backhaul
Having issues with iPhone 16 Max Pro's and iPad Pro's each will intermittently drop WiFi signal & WiFi calling and try to default toward using the cellular network. My setup is the following: F...
phillipsaz
Yes it is the 970 system Black Edition. I have a 2nd Sat but i don't have it online or powered up. It was overkill for my house. So, I did a Wifi scan on all my wireless networks and the backhaul broadcasts on random channels and I saw it used Channel 6 and Channel 44. Odd right? I would like to be able to just turn it off since my backhaul is wired..Process of elimination. However, they don't have that capability.
I am not clear on how WiFi 7 works. See the definition:
WiFi 7 operates on the 2.4GHz, 5GHz, and 6GHz radio spectrum bands and doubles the number of MU-MIMO (Multi-User, Multiple-Input, Multiple-Output) streams to 16, enabling WiFi 7 to handle more throughput than its predecessors.
I can never get my devices to flip back to Wifi when it drops and tries to go cellular.. It never reconnects, I have waited 5 to 10 min during troubleshooting. Thanks for replying..
Jan 27, 2025Guru - Experienced User
https://www.netgear.com/hub/wifi/mesh/orbi-enhanced-dedicated-backhaul/
Yes NG only uses 5 and 6Ghz for there MLO on WiFi7.
