joe_wht
Jul 04, 2022Luminary
? Best Setup ? Modem CM1200, Router RAX200, 2 GS308 Switches, 1 RN214 NAS
I'm looking for the BEST Setup, Wired (see pic), Would aggregation help any? Modem: Netgear Nighthawk CM1200, Router Nighthawk RAX200, 2 Switches Netgear GS308, Netgear RN214 NAS. Office Desktop...
Jul 05, 2022Guru - Experienced User
You can enable LAG between the CM modem and RAX200 router, then connect switches to the other open port on the RAX200 router would be recommended.
If your ISP only provides up to 1Gb, then you'll only see 1Gb across the LAG configuration at any time. Some ISPs have 1.4Gb so in this case you could see that over wireless if LAG is configured. Wired would not see this since all ports are 1Gb connection rates, even in LAG except for the multi gig 2.5Gb port then you might see 1.4Gb on this port, which would work best with a CM2000 modem. We've yet to see ISPs offering 2.5Gb yet.
joe_wht
Jul 05, 2022Luminary
Thanks for that!
Questions, ( sorry if they sound stupid )
I want the NAS, laptop & printer to have the fastest network communication. Office Desktop 2nd fastest. Then the 12+ entertainment devices last.
Will moving the NAS & Printer from the router to the switch have trouble being found?
Regarding the Modem CM1200. Right now only 1 port is used for the Router.
If / could I plug 3 rarely used devices in the unused ports and would it FREE UP speed on the router & switches or would it decrease speeds on the router & switches?
So, right now I'm planning to use LAG and use Router port 1&2 for Switches, port 3&4 for Laptop & NAS. Printer & Desktop + others going into the switches.
